Hole in hardwood flooring...how to patch?
Old 10-25-13, 12:46 PM
I
Question Hole in hardwood flooring...how to patch?
I have a hole in some hardwood flooring. It is perpendicular to the direction of the boards & spans 4 boards. So maybe 2 inches by 8 inches. It looks like a clean/deliberate cut because I can't see the ridges that help the boards lock up. Right now I just have expanding foam in there but wondering how would the pros fix that up?
Old 10-25-13, 02:46 PM
Received 821 Upvotes on 720 Posts
A pic or two would be helpful. Normally you remove the damaged boards and lace in some new ones.
Old 10-26-13, 08:55 AM
I
Ok, so I wouldn't just be patching the hole, you're saying I need to remove the whole board & put in a proper sized one. Didn't realize taking out the non-damaged portion.
Old 10-26-13, 01:55 PM
Usually if you just plug the hole - you wind up with a patch that you'll always see, maybe one that your eye is drawn to Lacing in a new board [s] along with proper finishing helps to make it look like the hole was never there.
Old 10-26-13, 09:24 PM
I
Got it. Figured there may have been something similar to a drywall patch for hardwood flooring but I guess not. Thanks.
Old 10-27-13, 05:21 AM
If you planned to cover the hardwood with another floor covering - it would be ok to just plug the hole. You could cut and insert a small piece of wood to fill the hole as a temporary fix but for it to look right - new [or salvaged] wood needs to be laced in.
