Which way to lay floor in single story
Received 0 Votes
Greetings. I'm planning on laying laminate in my condo and its my first time. It has a concrete sub-floor. I'm wondering if anyone could give me advice on direction to lay floor and where to position my line to make sure everything is straight. Any help much appreciated.
I'm thinking this is the best way, but not 100% sure.
Welcome to the forums! Laying the laminate north/south in the living room would be best, although there are no rigid rules. You will transition at each door opening and at the hallway, so you can lay the flooring in any direction you want in the rooms. Lay the hallway E/W.
