RV flooring for wide range of tempertures
Old 10-31-13, 01:52 PM
F
Cool RV flooring for wide range of tempertures
I need to replace flooring in my RV. The problem I want to solve is what to use in a space that gets below freezing and above 100F with varying humidity.
I was leaning to a LVT glue down to plywood, buy I think this will fail in the heat due to different expansions.
Second choice is a click and lock floating engineered wood. Fortunately the floor size is small, so I think the 1/4" gap at all ends is enough for the expansion and contraction under the 3/4 quarter round.
Any thoughts on what to look out for in those conditions?
Old 10-31-13, 02:07 PM
Received 1 Upvote on 1 Post
Almost all RV's use LVT with no issues.
