Laminate to Tile Transition Major Issue!!
Old 11-11-13, 04:48 PM
C
I began laying laminate flooring this weekend and got about 99% done, all the way over to my kitchen, which is laid in ceramic tile. It starts with a 3/8" plywood, then backer board, then the tile. Once I got my laminate over to the tile I realized how off it was. The tile is 1 and 1/8" high from subfloor to tile top. My laminate is only 1/2" thick. I know, now, that I should've laid plywood over the sub floor to account for the variance. What are my options? Can I salvage the floor? Or must I pull it all up, lay plywood over entire floor, then relay laminate and join with T- molding?
Old 11-11-13, 07:49 PM
XSleeper's Avatar
Received 1,948 Upvotes on 1,748 Posts
I would probably make a real wood transition, bevel it as needed to match the two different levels of the floors and stain and finish it to match your laminate as closely as possible. It would probably need a rabbet to fit over your laminate so as to cover the edge, allow some room for expansion and contraction but no fasteners would penetrate the laminate floor or the tile floor... just through the wood transition.
