How to fill these gaps?
Old 12-13-13, 03:38 PM
Good day
I was wondering if someone could recommend a solution to fill these gaps.
It doesn't need to be an elegant solution, but anything to make it look better than how it does now.
Old 12-13-13, 04:35 PM
R
Received 67 Upvotes on 52 Posts
Looks like laminate flooring and they just need to be pushed back together. I have seen some people put a small amount of wood glue between the joints prior to pushing them back together to keep them from coming apart.
Old 12-13-13, 04:52 PM
czizzi's Avatar
There is nothing that I know of that you can "fill" this with. It is an installation error that can be repaired by peeling back the flooring and installing it correctly. Providing of course it is laminate and not Vinyl tile.....Which type of flooring is it?
Old 12-13-13, 05:54 PM
thank you for the replies, to be honest I'm not sure which one it is (sorry I'm a complete newbie), but here's another picture of scratches which may indicate the type of floor?
i like the idea about pushing the pieces together, would I need special tools for that, how is that normally done?
Old 12-13-13, 07:01 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Oh, it's laminate. About the only way would be to pull the molding at the ends of the runs and use a tapping tool that you can get from box stores. Looks like a flat bar with each end stuck up the opposite direction.
Old 12-13-13, 08:05 PM
Received 1 Upvote on 1 Post
Who installed this floor?
One of two things had to have happened.
It was just installed wrong, or some things stopping the floor from being able to float.
If someone glued it to the floor, nailed the 1/4 rd. through the flooring, it's going to pull apart.
You'll need one of these, laminate flooring tools pull bar - Bing Images
Highly unlikely your going to be able to pull a whole row together like that.
Most likely It's all got to come out and be reinstalled. Good time to replace those chipped and scratched pieces.
Old 12-14-13, 06:29 AM
czizzi's Avatar
I'm still leaning toward a vinyl click and float floor. The exposed ends are a dark grey and the scratched areas are showing a dark grey under the finished topcoat. Those colors are not consistent with any laminate floor I have seen. Using a pry bar or tapping bar will do nothing as it may not be strong or stiff enough to push. Also, the ends were spaced to close to the adjacent end which is probably why they all moved together. Probably agree that one side is nailed at the shoe, the floor expands but only in one direction and does not completely come back, thus a separation at a weak link.
Laminate Vinyl Tile of Click System - China Laminate Vinyl Tile
Old 12-14-13, 07:52 AM
chandler's Avatar
Z you may be right (as usual) as it looks more like Allure on the ends doesn't it. In which case don't bother investing in the tool we mentioned. How long before you plan a total redo, or is that in the foreseeable future?
Old 12-14-13, 03:17 PM
thank you very much for the replies! unfortunately I can't plan a redo because I'm renting out. Thank you for mentioning the tool and even providing the links. Really appreciate your time everyone!
Old 12-15-13, 06:26 AM
chandler's Avatar
Go to your other thread. I think replacing these as well would be in the offing, too. You have determined them to be sticky tab Allure type flooring, right?
Old 12-15-13, 01:34 PM
yes that's correct, thank you for the tips once again I guess I'll just replace the pieces
