Repairing older wooden floors
Have you had the house treated?
Those bad pieces can be cutout and replaced.
You make two cut along the length about 1" apart.
Use an oscillating on the ends to finish the cut.
Remove that section.
Use A wood chisel and tap what's left toward the cut out area.
Remove the nails.
Cut a new piece to length and off cut tongue.
Apply some construction adhesive on the subfloor and tap the new piece in place.
Use a few long finish nails in predrilled holes to hold in place.
The new pieces are going to be thicker and will need to be sanded.
Remove the nails.
