Hardwood over parquet
I'm buying a co-op which has old (1950s) parquet over concrete, most likely glued. It's on the 10th floor, so there are no moisture issues. I'd like to install a new hardwood floor over the parquet. I know it can be done because an acquaintance, who has a unit in the same development, had it done about 10 years ago and it still looks good.
He said the installers nailed the hardwood to the parquet, with a layer of paper in between. I don't know the thickness of the parquet but I assume it's not more than 1/2". What sort of nails would be appropriate for this application? Aren't flooring nails typically too long for this? Any other considerations?
Thanks,
Steve
Thanks,
Steve
Welcome to the forums! Cleats and staples are usually 2" or longer, making it "iffy" on securing to 3/4" parquet. In addition, if the parquet is poorly attached to the concrete, nothing attached to it will be secure.
Go one better. Install 5/8" click lock engineered flooring. Very stable, looks really good, installs without fasteners, and most come with a 50 year wear warranty. Just food for thought. I have installed many, and they still look good today. I still prefer nail/staple down 3/4", but circumstances dictate.
Thanks for the response. A couple of comments:
As I noted in my OP, it can be done, since I have seen it.
I'm familiar with click-lock, but I want real hardwood, not laminate. Is there such a thing as click-lock hardwood?
Steve
A
Steve
A
Engineered flooring is not laminate. I wouldn't put laminate down anywhere. I can't say with your certainty that it will work. It worked in a different location, 10 years ago. I am concerned with deterioration of glues, etc. 2" is the absolutely longest cleat I would use. You are shooting at an angle and your cleat CAN act like a wedge, breaking the glue bond on the parquet. I am not saying this will happen, but you deserve to be informed. The ultimate decision is yours, of course.
The engineered stuff has a relatively thick layer of real hardwood over a plywood (or mdf in cheaper brands). IIRC it can be refinished 2 or 3 times, but the factory finish will last a long long time if cared for correctly.
Good info here....not endorsing this brand though...All About Wear Layers - Engineered Flooring
Thanks!
Thanks;
Thanks;
Welcome...
Lol... Seriously...if Larry recommends it, I'd definitely consider it since height doesn't seem to be a problem for you.
