laminate ove lineleom(sp)?
Received 0 Votes
I seem to have to install a laminate floor in two hallways after carpet came up
the subloor is covered in old 11950s lineoleum. really glued down tight
can I install laminate over it?
Laminate installed as a floating floor so that as long as the floor underneath is sound, you can install over it. Make sure you have an approved an appropriate laminate underlayment for sound deadening. If over concrete, you would want a vapor barrier built into the underlayment.
