drop and lock click system flooring
Old 02-15-14, 01:51 PM
F
Hi,
Can anyone tell me if drop and lock is a good click system? I have not heard of it and have seen laminate i like with this system which i am thinking about buying.
The reason i ask is i was previously going to buy laminate which was angle to angle but the expert i spoke to said it wasn't a good click system. I just want to make sure i am buying flooring with a good solid click system which wont show gaps between joins after a while.
thanks
Old 02-15-14, 02:10 PM
czizzi's Avatar
Either system is fine as long as you stagger the joints appropriately the seams between the boards on the short end should not release in the drop an lock method. In other words, I see very little difference between the to systems other than the drop and lock would be easier to install for a DIY'er.
