Tile to Laminate Flooring question
Old 03-20-14, 06:33 PM
C
I have laminate flooring in my main hallway all the way to the entry door. I am wanting to create a tile entry at the door. Is this possible? I'm not sure how to cut and transition with the laminate flooring already existing. Any suggestions will be appreciated. Thanks
Old 03-21-14, 05:08 AM
P
Received 1,763 Upvotes on 1,576 Posts
Yes, you can remove the laminate from a section and install tile. The big issue is that you may not like the difference in thickness/elevation between the tile and laminate sections.
