Installing Laminate In basement
i understand its best to use sub flooring on concrete before the laminate.. can I just use regular subfloor or is it better to use DRICORE that home depot has?
DRIcore | 2 Ft. x 2 Ft. DRIcore Engineered Subfloor Panel System | Home Depot Canada
Welcome to the forums. Have you done your moisture test, yet? Place a clear piece of visqueen about 3'x3' and tape it down to the concrete. After 24 hours see if you have moisture droplets on it. If it is dry, you could save a whole lot of headaches and money by graduating from laminate to engineered click lock flooring and not have to deal with the DriCore. Laminates aren't always approved for below grade installation, so check first.
Film-Gard | 9 Ft. X 12 Ft. Clear 2 Mil Drop Cloth | Home Depot Canada
i found this but its only 2 mil
I would not recommend laminate flooring in a basement, due to moisture. Have you checked into an interlocking (floating) vinyl plank, instead? This is definitely going to be your best bet.
