Simplest way to convert glossy hardwood floor to flat/matte?
Old 05-17-14, 09:14 AM
D
Received 1 Upvote on 1 Post
I have a (newer) Oak hardwood floor with the typical slightly glossy finish. No stain, natural.
Is there a trick in the trade for an easy conversion to a flat/matte/satin finish? Trying to avoid to go though a complete re-finish.
Old 05-17-14, 03:28 PM
Received 821 Upvotes on 720 Posts
Scuff sand the existing finish and apply a satin finish. Do you know what type of finish is currently on the wood? It's best to apply oil over oil and waterbased over waterbased.
Old 05-18-14, 08:02 AM
D
Not sure what finish I have. It is a prefinished Bruce.
What are they typically using?
What sand paper would I use for "scuff sanding"? 220?
Old 05-18-14, 10:37 AM
An oil base poly should do ok over the factory finish although it won't be as hard [scratch resistant] as the factory finish. I don't know if you can get the same type of coating they used
220 grit would be fine.
