Installing end cap
Installing end cap
Cut the moisture barrier flush with the floor so you can install base molding. You did leave at least 1/2" gap at the walls, right? Is this laminate or engineered flooring? Curious.
Not bad looking laminate. I have laid similar 5/8" click lock engineered flooring. So just trim all your excess underlayment. You aren't building a pool, just a breathing pattern for the flooring as well as some cushion.
