laminate over tile
I am looking for advice/opinions on
installing laminate flooring ( about 850 sq ft)
on top of 13 x 13 ceramic tile
concrete slab house/ 1999/ Houston Texas area
thanks
Mike
thanks
Mike
You've been around long enough to know what I think of laminate flooring. If the tile floor is in good shape, and you use a good underlayment, you can install it over the tile. You won't have the problems normally associated with an installation on a wooden structured floor. You'll still have the "clack", but that's laminate.
Chandler, do you think/know if I will have a problem of the recessed grout lines pattern transferring up through the laminate?
Would some the liquid type floor leveling compounds adhere to the glazed tile enough to eliminate this
Or am I over thinking this
