how to install laminate flooring around gas fireplace
Hi
Anyone know how to install laminate flooring around gas fireplace ?
Do i need to undercut it or use trim/molding to cover expansion gap ?
You can't use shoe or quarter round on laminate next to tile. You will need to use a termination transition strip to allow for proper expansion and contraction. The fastening system will attach to the floor and the laminate will be cut 1/4" or so short of that, then the transition strip will be applied to the fastening system. Definitely undercut the pilaster.
