Laminate flooring on stairway
Old 08-29-14, 07:57 AM
K
A friend of mine is looking to place laminate flooring on his stairway to the basement. I don't think I've seen this done in person so I was wondering if anyone here has done it. It seems like it would be a real pain in doing it. How would you start? How would you anchor it? I believe he's got stairs that are wooden now. We ripped up the old carpeting awhile ago to reveal this "beautiful" brown painted finish underneath.
Old 09-09-14, 11:52 AM
Tell your friend to buy oak stair treads at HD and install them instead. They look better and there is no worry of the laminate stair nose molding popping off. Otherwise Cut the pieces of laminate to fit depth and width of tread and glue down with construction adhesive leaving room for depth of stair nose molding. Cut the stair nose molding to fit width and also glue down. If he wants to do the riser put that in after tread is down, cut to fit height and width and glue. Or just paint riser to preferred color.
Old 09-09-14, 02:31 PM
sam floor's Avatar
Received 37 Upvotes on 31 Posts
Laminate needs to expand and contract. Doesn't really work on stairs.
