Kitchen Renovation - Floor Timing
We are renovating our kitchen and will be installing a floating laminate floor (Probably Pergo Max) over a concrete slab foundation.
Dave
- Should we install the new cabinets first and then install the floor?
- Should I install plywood under the cabinets to raise their base surface up to the expected final finished height of our floor?
- Should I just handle the required floor edge gap with transition molding or should I consider cutting the front edge of the cabinet under-layment about 1/2" too short so that the floor can just float under the front edge of the cabinets?
Dave
IMO... Yes, yes, and yes. And you should probably also plan on adding base shoe around the cabinets after the toe kick is on.
In front of cabinets, you should have a separate toe kick that's applied after cabinets are set. Once set, lay down floor. Cut accurately around cabinets so you can cover gap with 3/4 round molding. If you don't have the 3/4 round I would suggest ordering some. 3/4 round finishes off the cabinets and adds a touch of class.
See instructions for floor. In wet areas, all gaps should be filled with high quality silicone. Floor will still float with silicone at edges.
I'm surprised Chandler hasn't chimed in yet but, while this is not what you asked, I would not put laminate in a kitchen as it does not withstand water well at all.
But it's true, the smart money is to avoid it if possible.
I put laminate in my kitchen. It's high quality DuPont.
The seams lock so well, normal water will not penetrate. The silicone filled edges are critical, if water gets under the boards, it's time for a new floor.
Laminate's not for everyone, I have the luxury of being able to replace it at a reasonable cost if I ever have a flood.
I didn't mention it before, but I would stay away from Pergo. I have only seen bad looking floors.
I believe they started this laminate trend, but others have far surpassed them in quality.
Put laminate in a kitchen at your own risk. Most leaks will be hidden from view and will get the floor from below. If this is your intended route, but 2 extra cases of flooring and stash away for that rainy day that will come. The style will be discontinued by then and you will be SOL.
I also would not recommend sealing gaps with silicone. Not sure what that means, but if around the edges of the install, it is a no no. A floating floor need room to move. Any obstruction, even if flexible, will cause issues with the flooring.
Maintain your expansion gaps, cover exposed with transition strips or Base + shoe molding. Make sure that your underlayment is a combination sound deadener and vapor barrier.
