Go Back  DoItYourself.com Community Forums > Interior Flooring, Floor Coverings and Coatings Center > Solid Hardwood, Engineered and Laminate Flooring
Reload this Page >
Refinishinng 1970's top nailed oak hardwood. Drum sander went well but......
Old 12-01-14, 05:20 PM
The floor edger did this (pic). I noticed this long streak about 6 inches wide that was slightly more noticeableName:  20141130_205658-001.jpg
Size:  9.1 KB than the passing I did with the drum sander. Before I stain my floor next weekend is there a way I can fix this so its not this noticeable ? I did 36, 60, and 80 with the drum sander and just 36 with the power edger. Shall I use my belt sander to fix ?
Old 12-02-14, 03:57 AM
Received 800 Upvotes on 703 Posts
It looks like you didn't sand enough with the edger. Do not use a belt sander! you are more apt to do damage than make it better. You could also use an orbital sander to finish it off.
