laminate transition issue
Old 01-18-15, 06:57 PM
A
I recently bought a house and I have laminate flooring in the dining room and kitchen. The dining room has French doors to the back yard. The house was built late 50s early 60s and comes equipped with water baseboard heat. The issue I have is the French doors and laminate flooring were an after thought and where the floor meets the door about an inch and a half or so of the floor is literally floating over a hot water pipe. The water pipe has warped that portion of the floor and I am looking for a permanent fix.
Old 01-18-15, 07:06 PM
Received 1 Upvote on 1 Post
Can't see it from here without a picture.
Old 01-19-15, 03:19 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Welcome to the forums! Pictures would certainly let us see what you are seeing and help us give better information. http://www.doityourself.com/forum/el...your-post.html With laminate flooring your options are limited to replacement or making a wide trim strip to cover the area. We'll wait on the pictures .
Old 01-19-15, 05:06 AM
A
pics (sorry for the delay )
here are the pictures let me know if you can help. I appreciate any ideas. Thanks again.
