Pine, can these be saved?
Old 02-07-15, 06:48 AM
P
Are these refinishable?
Size:  43.2 KBName:  image.jpg
Size:  41.5 KBName:  image.jpg
Size:  44.1 KBName:  image.jpg
Old 02-07-15, 07:01 AM
the_tow_guy's Avatar
Received 212 Upvotes on 170 Posts
One of the flooring pros should be along, but my layman's opinion would be absolutely.
Old 02-07-15, 07:06 AM
Received 1 Upvote on 1 Post
They can be, but not much you can do about all the gaps.
Going to be a pain to try and sweep clean, all the dirt goes into the gaps.
Any idea what's under it?
Old 02-07-15, 07:08 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Although we can't see all the flooring, from what you have posted, absolutely they can be salvaged. A good square pad vibrating sander would probably be the best tool to avoid gouging, and should remove the old finish just fine. Marksr will be along with finish ideas.
Old 02-07-15, 07:32 AM
P
I just didn't know becuase of soft pine, I figured nothing can do about the gaps. No clue what's under, figured not much.
What type of pine?
Old 02-07-15, 07:53 AM
Received 800 Upvotes on 703 Posts
It would be best to sand it all down to bare wood and then apply the finish [3 coats] There are fillers that can be used in the gaps but how well the filler will stay in place depends a lot on how stable the wood is.
Old 02-07-15, 11:14 AM
Old pine can be very durable - tons of old houses have pine flooring, I'm acquainted with old pine rafters so hard that you can't pound a nail into them. Worth doing, in my amateur opinion.
