Parquet Flooring
Old 03-16-15, 07:07 PM
Z
Parquet Flooring
Hi Everyone,
I have an older condo in which I plan to redo the floors. I am a bit up in the air between laying down laminate floor and re-finishing the existing parquet. As evidenced by the attached photos, the parquet has some pretty rough spots.
Will sanding and refinishing these floors remove stains that bad or will I be left with the stains and discolored areas ?
Any advice will be appreciated.
Size:  39.3 KBName:  FullSizeRender(1).jpg
Old 03-16-15, 07:19 PM
Received 1,261 Upvotes on 1,203 Posts
Is the wood stained or is that in the finish?
If it's in the wood, you may be able to bleach them out.
Laminate is a last resort, I'd try to fix this first.
Old 03-16-15, 07:27 PM
Z
It is really quite hard to tell. I believe the floors are original from 1967 and I have no idea as to how long they may or may not have been covered by carpet.
I attached another image that might give a better look..
What would be the best way of determining if the wood is strained or if it is in the finish, short of getting a floor sander on them ?
Old 03-17-15, 04:47 AM
Received 821 Upvotes on 720 Posts
nothing ventured, nothing gained ..... but I'd be surprised if you can sand/bleach those stains out
Go ahead and try a section and see how it goes [I've been wrong before] just don't get your hopes up
