Holes Cement Prior Engineered Flooring Installation
Old 03-31-15, 05:28 AM
K
After ripping out my carpets and the wood nailed to the slab there are many holes (most not too deep) in the cement. Should I fill these holes with some type of floor leveling compound prior to installation? Maybe it really doesn't matter? Thanks!
Old 03-31-15, 05:31 AM
Norm201's Avatar
Received 726 Upvotes on 642 Posts
I would!__________________________
Old 03-31-15, 06:31 AM
Received 128 Upvotes on 113 Posts
A picture might help.
If there just the tiny flaws where the carpet strip nails where the flooring will span those with no issues.
Old 03-31-15, 06:55 AM
K
Pic Holes in Cement Prior Hardware Installation
Sure..here is a pic. Thanks for everybody's advise and suggestions!
Old 03-31-15, 06:58 AM
Not big enough to be an issue, but no harm in filling.
Old 03-31-15, 12:49 PM
czizzi's Avatar
No need to fill in with engineered flooring. I would, as a caution, at least drag a putty knife over each hole. Sometimes the concrete nails holding the tack strips break off and leave an exposed point. Couple of good blows with a hammer to flatten them out.
