DO I need to level floors
Old 04-14-15, 08:29 AM
K
I am going to put laminate throughout house over hardwood(that irrepairable to where I want it). I know 1 room will need it but is the concave bad enough in the other areas that it will need it too? How many bags should I get? The board I used is 100% straight and 69" longName:  IMG_0397.JPG
The worst spot is where I have my pinky for reference
Size:  43.1 KBName:  IMG_0375.jpg
Size:  14.0 KBName:  IMG_0375.jpg
Size:  14.0 KBName:  IMG_0368 (1).JPG
Old 04-14-15, 08:43 AM
K
and the board is 4.5 in tall
Old 04-14-15, 01:22 PM
Received 128 Upvotes on 113 Posts
As bad as that is I'd be under the floor in the crawl space or basement seeing how to fix it.
Old house = over spanned, undersized possible fungus or insect damaged, cracked joist.
Picture under the floor in that area would be great.
Old 04-14-15, 02:27 PM
czizzi's Avatar
How is the level going parallel to the floor direction? All you dips are showing perpendicular to the direction of the floor.
It is also possible the level you show is caused by a single "high" joist which makes the rest of the floor look like it has a dip when it really is flat.
