T molding not even
Old 04-25-15, 02:20 PM
P
T molding not even
i was installing tmolding and my new floor is about 1/4 inch higher than the tile floor its butting up against. so the t molding is uneven. is it noraml to have a little unevenness? what are some suggestios you guys would have . thanksName:  do it your.jpg
Old 04-25-15, 04:38 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
You likely need to cut or plane a bevel on the bottom portion of the T-moulding (the part that would be sitting on the subfloor). If it's too tall, it will never sit flat on both sides.
Old 04-25-15, 09:12 PM
sam floor's Avatar
Received 37 Upvotes on 31 Posts
I think you can still buy offset T molding.
Old 04-26-15, 11:28 AM
Received 128 Upvotes on 113 Posts
Can not use a Tee molding there, need something like this.
https://www.google.com/search?q=Perg...39781121990104
