transition between tile Allure Vinyl plank
Old 07-21-15, 02:11 PM
R
I'm looking to do a floor myself with Allure Vinyl Plan which is only 4mm thick (.157 inch).
I wonder how transition to tile would work? will we feel the difference in height when material change?
Old 07-22-15, 05:39 AM
Received 128 Upvotes on 113 Posts
May want to use the search funtion on here and take a look at the thousands of post about Allure.
I know I would not use it again.
It has to be able to expand and contract so you'll need a transiion strip.
Adding a layer of 1/4 subfloor rated plywood may get them almost level so you could use a Tee strip.
