do I need to patch these concrete chunks before laminate
Old 07-21-15, 08:27 PM
Or will covering it with vapor barrior be good enough
Imgur
Imgur
Old 07-22-15, 04:48 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I would remove them and use concrete patch in the divots. I would not, however, install laminate below grade on concrete. Actually, I wouldn't install laminate anyway, but especially on concrete. Have you checked for moisture in the slab, yet?
Old 07-22-15, 10:28 AM
Fast setting quickcrete work ok to patch?
This slab is not sub grade. Its a single story house that's 50 plus years old.
Have not checked for moisture, but shouldn't the vapor barrior take care of that?
Old 07-22-15, 02:14 PM
chandler's Avatar
You can use this. It is premixed. Quikrete 10 lb. Vinyl Concrete Patcher-113311 - The Home Depot
If you trust the installation of the vapor barrier and its quality, it will keep some condensation at bay. If you have a moisture problem in you slab, it is not advisable to install laminate. It will absorb water and will deform. To test your slab, tape a clear piece of plastic sheeting on all sides to the slab. Leave it for a few days and see if moisture collects on the plastic. If it does, then you shouldn't install laminate.
