Laminate flooring and bullnose doorway ?
Old 07-29-15, 06:56 PM
ok so carpets all ripped up and im ready to lay laminate on my slab with a vapor barrior.
but how do i handle this?
iv got no problem cutting around the bullnose with expansion gap but im worried about how to cover that gap.
doesnt look like ill be able to use trim in this area
what are everyones thoughts?
Old 07-29-15, 07:29 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
Undercut the door jamb, door stop and bullnose so that the floor can slide under just slightly, which will still allow room for expansion provided you clean out behind it.
Old 07-30-15, 04:35 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Is that a metal door jamb? Or just a lot of paint? Cutting base trim for bullnose isn't difficult. You would cut 22.5 degree angles on three pieces allowing the smallest piece to be installed across the bull nose, then caulk the gap when finished.
I am concerned with your installing laminate on a slab. Is this above or on grade, or below grade? Have you done a moisture test? Is your laminate designated for below grade installation?
Name:  bullnose corner.jpg
