Wrong Subfloor?
Wrong Subfloor?
I hired a contractor to replace my subfloor over 400 sq ft in two rooms on my first level. Upon completion, I realized they used 3/4 in plywood sheathing instead of 3/4 in tongue and groove plywood.
I plan to put down laminate or engineered hardwood.
Will this be OK? Is this typical?
Yes, T&G would have been ideal. 1 1/4" of subflooring is also preferred. We don't know the spacing and size of your floor joists, nor the unsupported span. Having that information would garner better responses.
I've used nothing but Advantech sub flooring since it came out many years ago.
Far better then plywood.
One layer and your done.
Compare To The Strongest Plywood Floors, Prevent Floor Squeaks, Quiet Floors | Huber Engineered Woods
Sheathing is full of voids in the core, and if it's not T & G it's going to flex at the seams and cause squecking.
If it was mine I'd go over the whole thing with A/C 1/2" plywood making sure not to have the seams line up with the seams below and not nail to the joist.
20 years ago that was just the way it was done, not any more.
The joists are 16 OC. I couldn't believe it when I noticed given that t&g plywood is only a dollar or two more per sheet and i wasnt even consulted... although I've been called a perfectionist before so I was hoping that this would be fine.
You should be OK, just make sure that there is an expansion gap between boards. Look for markings on the panels and compare to the minimums listed in these wood flooring guidelines. Page 25 refers to subfloor preparation. It states a minimum 5/8" plywood panels - you have 3/4" So I think you are safe. While I usually go for the additional 1/2" like others mentioned, I understand your height restrictions. Did they screw the panels down or nail? If nail, add some exterior deck screws or rated subfloor screws to keep things quiet.
http://tinytimbers.com/pdf/nwfa-install-guidelines.pdf
