Removing stains left by foam/rubber underlay
Old 01-17-16, 03:00 PM
A
Hello, I recently removed carpet. From my stairs and there was a foam/rubber underlay glued to wood. It comes up pretty good by scraping but not completely and there's quite a few black spots. Is there any way to bring this up to restore the steps? They would be in good shape just to paint and replace the stringer. Please see picture. Thanks in advance.
Old 01-17-16, 03:03 PM
Received 1,248 Upvotes on 1,192 Posts
I've removed this residue previously with mineral spirits and a scraper. Make sure you have good ventilation if you go down this route.
Old 01-17-16, 03:04 PM
Received 800 Upvotes on 703 Posts
The pic isn't showing - http://www.doityourself.com/forum/el...your-post.html
Are the treads finished or was the carpet installed over bare wood?
Old 01-17-16, 03:09 PM
A
The carpet had a foam underlay stapled then this black rubber foam. Seems redundant to me.
Old 01-17-16, 03:16 PM
A
Here they are. Tried some stuff to loosen carpet adhesive, didnt work. more worried about the black color left.
Old 01-17-16, 03:26 PM
As mentioned above, scrubbing and scraping with mineral spirits [along with a lot of elbow grease :eek] should remove it but it will also stain the wood. Not a big deal if you paint but could hamper any type of natural or stain finish. Sanding will also work. Neither would be a job I'd look forward to
Old 01-17-16, 08:30 PM
sam floor's Avatar
Received 31 Upvotes on 26 Posts
Try a little hot water and elbow grease. That rubber backing came off a glue down carpet and if you are lucky it was installed with latex adhesive.
Old 01-18-16, 08:26 AM
A
Thanks to all who replied. Will try the hot water and if no luck will get some mineral spirits.
