Floor install adjust flexibility
Hello,
Because of doggie and propensity for marring, have decided on laminate or engineered flooring......
Have rooms: 12x25, 13x25 and the one am most concerned about is 45x22.
The largest one has 1/2" difference where actual is 45X22 on one end to 45x22 1/2 on the other end...The other large rooms have one precise and the other problem has a lengthwise difference of 1/4".
Since they'll have baseboards and I intend to install myself, how much compensation can I expect and will I be able to adjust along the way to make it disgustingly precise. Concisely, is there any tiny bit of flexibility in the flooring itself to pull/push however slightly adjust the difference along the way to make it come out even.......Went to Lowes, clicked a sample together and wasn't too encouraged.
Good advice gratefully accepted...
Flbuild.....
Central FLorida
Flbuild.....
Central FLorida
Send a link to the actual flooring. Laminate in excess of 35 feet usually needs an expansion joint. Opt for a factory finish and look specifically to the warranty of the actual product as it pertains to pet scratches. Most will not cover them which means that the floor will scratch if your dogs are actual dogs who like to have fun.
Fretting over 1/4" to 1/2" in a room thats 45'x22' is pretty laughable, if I can say so without going down in flames.
If, by 22 1/2, you mean 22' 6"... that's a different story.
Well fl, you have done your homework and figured how the floor will lay out.
I just want to ditto sleeper and say this is not an issue even though there is no flex or give. It's actually a pretty square room.
You wouldn't believe how out of square some houses can be. I have stories
