Is this a hardwood floor
Old 07-09-16, 08:32 AM
Michael_G's Avatar
Question Is this a hardwood floor
Hey all,
My mom's house, built in 1962, has hardwood in every room but the kitchen, bathroom, and one bedroom. The one bedroom has carpet. I was planning on replacing the carpet but when I pulled it up I noticed what might be wood flooring but it doesn't look like the rest of the wood flooring in the house. For one, it runs perpendicular to the rest of the wood flooring in the house and it's much wider from what I can tell. Even though it's different than the rest of the hard wood, if it is truly hardwood, I'd probably get it refinished instead of carpeting.
Let me know if you have any ideas. I'm shared out three images. Two are around the vent and one from the top. The area around the vent is what throws me because there is a piece of 1/8" wood that is separated from the rest of what I assume is the underlayment but it also could just be part of the underlayment that separated but that just seems strange.
https://1drv.ms/f/s!AuS1xumH3tqoz1dCHDiULxz7JqzA
Thanks in advance,
Michael
Old 07-09-16, 09:11 AM
F
Looks like plywood to this kid. Definitely not something to be used as a finished floor.
I could, of course, be wrong.
Old 07-09-16, 09:21 AM
Received 740 Upvotes on 646 Posts
Looks like plywood to me also.
Old 07-09-16, 01:09 PM
Handyone's Avatar
3rd confirm. That's definitely plywood.
You could place a wood floor or laminate on top of it if height's not an issue.
Old 07-09-16, 03:35 PM
Received 125 Upvotes on 110 Posts
Looks to me like there's at least three layers of sub flooring.
Old 1 X 6 diagonal pine, then what looks like two more layers of plywood for some reason in the second picture, look close at the fine dark line between the layers.
Old 07-09-16, 06:15 PM
Michael_G's Avatar
Thumbs up
Great! Thanks for the confirmation. I didn't think it was hardwood but it's always good to get several opinions.
