indents on hardwood floor and uneven coloring
Hi, I just sanded my floor and stained it, and it is coming out with dings (imperfections) and also there are indents where the nails are.. what can I do to fix this?
Below are my photos. Appreciate your help!
Live with it. Make friends with words like "patina" and "character".
Seriously, are you open to the option of completely sanding and re-finishing the floor again?
To get rid of the dents and imperfections you will have to sand down below the lowest dent, and that can require removing a lot of material. I like PDs suggestion of "patina", seriously. It will help mask future dents and scratches. And you're done.
Bud
Bud
I agree, too much work to fix it [sand and start over] plus once the furniture is put back in the room maybe a throw rug here or there - it won't take you long not to notice it anymore.
From my experience, you might get in over your head if you try to make an old floor look perfect.
It will take a drum sander and the wood needs filled with a paste wood filler. The paste filler is not easy to apply and finish properly. It can make a floor look great, or ruin it.
The floor looks good IMO and I like the level of sheen.
Go to a matte finish on your poly as it will be more likely to not show imperfections like a gloss finish would,
