cutting engineered wood
Received 0 Votes
Hello, I was wondering what tooth blade I should use for cutting engineered floor planks. Thank you
You would want a medium blade in the 60 tooth range. You didn't say whether end cut or rip, so we don't know if you are talking cut off saw or table saw. Also good advice is free, so here goes. Cut from the back side of the flooring when possible. The aluminum oxide coating on the flooring dulls blades quite quickly.
