New laminate to match old laminate
I moved into this house about 10 years ago. It's now time to replace the carpet in the living room. I've decided to go with laminate.
The kitchen had laminate when I moved in- looks pretty new.
How do I go about matching the living room with the kitchen? Or do I need to?
Thank you!
Thank you!
There is no need to match it.
Add a transition strip and add whatever you want.
Really want to match it go to your local box store or real flooring store and pick up some samples, 10 year old flooring good luck on finding a match.
We have no picture so it's anyone's guess what you have now.
Often you are better off going with something different (using a transition as joe said). That usually looks better than a close, but not perfect, match.
I agree, try to match and fail and it will usually stand out more than something which is contrasting.
