How do I tell if this is "hardwood" floor?
SO I found out recently that there is a wood floor under our carpet which I have been wanting to get rid of since we moved in to the house. Problem is, its clearly not finished by any means. Question I have is this a wood floor I could finish and seal and use?
https://*******/d5LLJQ
https://*******/iadkk5
The layers are called "plys". And the sheet edges will be every 4 or 8 ft, since the sheets are 4x8. And it's all face nailed every 8" or so.
