Sanding Sealers and Poly: Can you use water-based with oil?
Old 11-22-17, 06:39 PM
B
Received 5 Upvotes on 2 Posts
I've been debating whether to go with a water or oil based poly for my red oak floors. I know the curing time and smell is longer with the oil but the finish product is much better.
I'm going to be using a sanding sealer and wanted to know if I go with a water-based sanding sealer, can I use an oil-based poly over it without any issues?
I'm having to buy products locally - likely Home Depot - and was looking at the Miniwax water-based sanding sealer. Or the Zinsser Bulls-eye Seal coat Shellac - if I have to use oil sealer for oil poly.
For the Poly I'm looking at the Rust-Oleum Pro Finisher 275 VOC.
Old 11-22-17, 07:27 PM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
Just read the label. Minwax sanding sealer is water based but it says on the label it can be used with either oil or water based poly. If you use a different brand of poly, like the Rustoleum... well, you would have to read that label to see what it recommends. (Pro Finisher Universal Sealer)
Old 11-23-17, 01:53 AM
Received 741 Upvotes on 647 Posts
An oil base sealer will deepen the colors naturally in the wood, a water based sealer does not. While an oil base poly applied over a water based sealer will amber some as it ages, it will not deepen the colors any because the water based sealer has already sealed the wood. If any spots are missed or sanded thru - those spots can change color once the oil poly is applied. When water based sealer/poly is used and you want the darker effect you need to use a light stain first. A lot depends on the look you are going for.
Old 11-23-17, 07:29 AM
B
Do I need a sanding sealer if using oil-based poly?
Old 11-23-17, 07:42 AM
B
Marksr, what about if I use that Zinsser shellac sealer? Would that be the right kind of sealer to use to allow the poly coats to penetrate?
I read that before there ere sealers people used to cut the first poly coat with 10% mineral spirits.
Old 11-23-17, 08:19 AM
XSleeper's Avatar
The entire purpose of using a sanding sealer is to smooth the surface. Your initial coat of finish (whether it is poly or sanding sealer) is going to raise tiny wood fibers and drag impurities around on the floor... and you will be left with a relatively rough surface that needs to be lightly sanded.
So you want your first coat to be easy to sand. That's where sanding sealer comes in. When lightly sanded, it turns to a powder and leaves you with a nice smooth surface. Once you have cleaned the dust off, you are ready for your floor finish... and you will lightly sand between each coat just to remove impurities.
Old 11-23-17, 02:47 PM
Since not all sanding sealers and polys are compatible with each other - most just apply 3 coats of poly, sanding between coats. I always use sanding sealer under varnish [on woodwork] I only have a little experience with clear/tinted shellacs.
Old 11-24-17, 04:08 PM
B
Edit. Taking back the Sanding Sealer I got.
