How to transition from hardwood floor to door frame?
Old 11-26-17, 07:27 PM
B
Hello. Complete beginner here. Just finished construction of my new home and am trying to complete a few projects.
I had Shaw Epic Plus engineered hardwood floors installed in my house. Overall, the guys did a pretty good job. However, I've got two areas that appear unfinished. It's where the floor meets two door frames. I can still see the sub floor.
I'm wondering if there is a product that I could buy and install to cover this transition area. I do still have quite a bit of the flooring left but I'm not sure that I want (or would be able) to rip pieces to fit in the gaps.
Does anyone have any idea what I could do here?
Old 11-26-17, 07:32 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
If clearance is a problem, rip a piece of flat trim that matches the floor, slight round over on the leading edge. If you have plenty of height to work with, baseshoe would work. U will have to stain and finish it to match.
Old 11-27-17, 01:47 AM
Marq1's Avatar
Received 946 Votes on 859 Posts
So your installers did that?
Personal I'd demand that they come back and repair.
What they should have done is undercut the casing molding, and trimmed the wood so it would extend out to the bottom door frame for a neat butt joint. In the bottom picture it looks like there is a small piece about the same length as the width, that is also a no-no.
That sloppy work is unacceptable!! You should not have to patch up a new wood floor that was not installed correctly!
Old 11-27-17, 02:29 AM
Received 672 Votes on 595 Posts
I agree, get the installer back to finish - that is not a finished product ..... which I assume is what you paid for.
Old 11-27-17, 05:39 AM
XSleeper's Avatar
Most wood floors need an expansion joint around every perimeter so it's not that unusual to see a gap there.
Old 11-27-17, 09:29 AM
While I know it's common procedure to have a gap that is hid by the base or shoe mold, I've always seen them lay the hardwood tight to thresholds. .... which is how I did it in my foyer about 20 yrs ago - still looks good.
Old 11-27-17, 03:15 PM
czizzi's Avatar
Received 15 Votes on 13 Posts
What type of installation - nail down or floating?
Old 11-28-17, 01:50 AM
Marq1's Avatar
For doors I always butt the wood up to the frame, if there is concern you can easily leave a small gap and caulk.
But this is not an expansion gap its a case of horrible workmanship.
https://www.doityourself.com/forum/a...1&d=1511862613
Old 11-28-17, 05:08 AM
B
This has been glued down.
