Removing glue/thin-set from red oak flooring
Old 11-18-18, 08:04 PM
B
Received 5 Upvotes on 2 Posts
I can't tell if this some kind of adhesive or thin-set that was used to attach the tile. The tile was likely added in the 60s.
Is there a stripper/solvent I can apply to see if it will soften and scrape off?
Ultimately I'm going to have the floors refinished by professionals but if I can get some of the material off and make their job easier - and cost less - that would be great.
Old 11-19-18, 01:38 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Any solvent might damage the wood, if it is thin set/mortar then should be able to sand through the remaining residue!
Old 11-19-18, 04:59 AM
Received 1,262 Upvotes on 1,203 Posts
If you can't scrape off any more than that, I'd say you're ready for the finisher to come in and take over.
Old 11-19-18, 05:37 AM
B
Kind of dumb to think about it now but is there any visible indicators that it might contain asbestos? It doesn’t like fibrous.
Old 11-19-18, 05:53 AM
Received 824 Upvotes on 722 Posts
Judging by the size of the removed tiles there is a good chance they were asbestos tiles, don't know about the adhesive.
Old 11-19-18, 03:02 PM
B
These were stone or some composite stuff. Not like thin vinyl tiles. Not sure if that makes a difference in terms of what materials did and did not have asbestos in them back then.
