Laminate flooring wont snap together!
Old 11-25-18, 12:51 PM
W
Received 1 Upvote on 1 Post
I have quick step laminate flooring and no matter how I try it wont snap together. I have seems everywhere! I've watched videos and I'm doing it the way they say to do it which is to angle one piece to another and snap it down. If I get a good fit on one end of the board I have a seam at the other.
The boxes have sat in the house over a week before I started. Have I just got cheap flooring!?!?
Old 11-25-18, 12:55 PM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
If you have gaps everywhere then you need to start over. You shouldn't have gaps anywhere... so your very first row must not be straight or locked together.
Old 11-25-18, 06:09 PM
czizzi's Avatar
Check the grooves for debris and other specs of junk, a major cause of planks not interlocking. Check your stagger, boards should be staggered by 1/3rd of a board minimum. As stated, everything needs to be straight for things to lock down. Often times on thinner laminate, there is a slight warp or bow to the board which needs to be noted when lining up the tongue and groove. Before trying to engage, make sure you have good contact along the entire length of the plank.
Old 11-25-18, 07:00 PM
Received 23 Upvotes on 18 Posts
Do you have the special tool for tapping the planks tightly together? It's a plastic block that gets placed against the plank and you tap it with a mallet to force the tongue into the groove.
Old 11-26-18, 02:10 AM
Marq1's Avatar
Received 1,110 Upvotes on 1,010 Posts
Ive only done a couple of small areas in the basement with laminate, one 15 years ago was tongue and groove glue down and a piece of cake to install. The last one here in this house was a snap fit and I struggled with it the entire project, never again!
Krap in the grooves from milling process prevented installation and simply not happy with the fit, if I didnt mention, never again.
Old 11-26-18, 06:09 PM
czizzi's Avatar
Never use a tapping tool with laminate, it simply is not needed. I have installed every laminate floor with nothing but my bare hands. Tapping tools leave mark on the laminate that destroy that board and you have to throw it out. If you need a tapping tool, you are doing it wrong. Have installed high end laminate and bargain basement, all went together without any sort of tapping tool.
Old 11-26-18, 06:21 PM
Wasn't aware of that. I've only installed two laminate floors in my lifetime, on Pergo and one bamboo and use the tool on both. No marking. Guess I got lucky.
Old 11-26-18, 07:48 PM
czizzi's Avatar
You may be OK with bamboo as it has some rigidity, but normal laminate will chip along the edge if hit wrong with a tapping tool. I just figured out how to make it happen without the tool. It can be done, just a little technique that needs to be learned.
