I pulled up the carpet and plywood and found these beauties. Only issue is there is no subfloor. It's a real pain to pull up the plywood cleanly and very time consuming. Being that there is no subfloor, on a limited budget, and limited time, am I better off covering this back up and putting some hardwood in? The boards are 2-3 inches thick. Any thoughts on what wood this might be? Located in Vermont.[url=https://unsee.cc/9d8212b9/][/url]
So I’m attempting to lay a floating floor in a room, and have a question about the transition into the room. As the picture shows, the transition doesn’t have a T-piece.
how do I approach this? I believe the periodic use board is glued down, and I know the floating floor needs space to expand
