Which water based polyurethane should I go with?
Old 05-25-19, 03:44 PM
Hi. I know that Bona is the best but I need to finish my floor as soon as possible. I also dont know how much finish would I use so the ability of returning leftover cans is a must. Do you have any experience with any of those?
- Varathane Clear Matte Water Based Interior Polyurethane (linked below) for $54 / gallon.
https://www.homedepot.com/p/Varathane-1-Gal-Clear-Matte-Water-Based-Interior-Polyurethane-2-Pack-286820/205926960
- Parks Pro Finisher Water-Based Poly for $40 / gallon
https://www.homedepot.com/p/Rust-Oleum-Parks-Pro-Finisher-1-gal-Crystal-Clear-Satin-Water-Based-Polyurethane-for-Floors-258690/202521739
- Varathane Ultimate Water Based Poly for $49 /gallon
https://www.homedepot.com/p/Varathane-1-gal-Clear-Satin-Water-Based-Interior-Polyurethane-200231/100176203
- Sherwin Williams Waterbased Poly for $45/gallon
https://www.sherwin-williams.com/homeowners/products/wood-classics-waterborne-polyurethane-varnish
Old 05-25-19, 04:01 PM
XSleeper's Avatar
Received 1,924 Upvotes on 1,728 Posts
You shouldn't really use regular poly for floors. You want to be sure that whatever you choose, your poly specifically says it is for floors because it will be more durable.
Old 05-26-19, 02:53 AM
Received 840 Upvotes on 737 Posts
I have very little experience with water based polys. Oil base poly dries to a harder finish which means it will wear better. If I were to use a water based poly on the floor I'd see what the local hardwood distributor has. There are some 2 part water base polys that dry to a hard finish.
