Underlayment question
Old 07-16-19, 08:53 AM
Going to be putting laminate in basement in the next few months.
The laminate I purchased does not have any underlayment attached. I have also bought DeltaFL plastic underlayment.
I know I need a cushion-y layer in between, which of these 2 options is "better" (it's the Canadian HD site):
https://www.homedepot.ca/product/rob...oll/1000753691
https://www.homedepot.ca/product/rob...ors/1000862838
The black product claims to be "2 in 1" but I can't really figure out what the 2 layers are. That one is cheaper psf, however, I also noticed it's thinner.
Any advice? If I choose one over the other, will i need to buy another product to pair with it?
I also noticed other "underlayment" products on the website that are cheaper psf but maybe they don't check off all the boxes?
Old 07-16-19, 10:29 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
This was the Roberts product that is specifically for basements, you dont want any felt down there!
https://www.prosourcecenter.com/prod...RoC56UQAvD_BwE
Old 07-16-19, 07:32 PM
sam floor's Avatar
Received 37 Upvotes on 31 Posts
What does the manufacturer tell you to use?
Old 08-23-19, 06:50 AM
I
Received 1 Upvote on 1 Post
I've tried few houses using underlayments from Lowe's and Home Depot, averaging $.56/sqft. But I had better luck with $.12/sqft 3-in-1 from Best Laminate for laminate floors. The term 3-in-1, is Moisture Barrier, Sound Barrier, and Cushion. Wouldn't know how they would perform in basement, though.
Old 08-23-19, 04:05 PM
Received 1,267 Upvotes on 1,207 Posts
Laminate is not generally a good choice in the basement since they usually have some degree of water infiltration and laminate cannot typically handle water.
