Laminate flooring transition piece
Old 08-27-19, 03:41 AM
I need help on what to do for a transition piece between laminate flooring and bathroom tile. The bathroom has a marble transition piece already. Wondering if I can cut a side off a transition piece and butt it up against the marble trim.
Old 08-27-19, 04:35 AM
XSleeper's Avatar
Received 1,712 Upvotes on 1,536 Posts
You could, if there is a height difference.
Old 08-27-19, 04:41 AM
N
Received 20 Upvotes on 18 Posts
Depending on the heights of the floors, you could either use a transition piece from the laminate floor manufacture or if your seams are really good, a piece of metal edging for tiles. We did one room with the metal edging, slide it under the laminate flooring and it turned out nice. took some effort to get a perfectly tight cut but got it in there.
Old 08-27-19, 07:59 AM
Marq1's Avatar
Received 1,103 Upvotes on 1,003 Posts
If you have a marble sill /threshold that is under the door it probably sticks up quite a bit meaning you want to use a "T" transition and cut off one side so it butts up to the marble!
I had posted a picture of how I did my basement but will try to find!
Old 08-27-19, 04:04 PM
Hey Marq1,
Yes I do have a 72" t transition for the other doorway. I will try as you say and cut a side off.
Old 08-28-19, 01:31 AM
Marq1's Avatar
I found the thread with the picture of how I installed the T molding next to the threshold.
https://www.doityourself.com/forum/f...ont-cover.html
