Engineered Hardwood to back door transition
Old 12-10-19, 01:02 PM
D
Hello all,
I have engineered hardwood floor, floating, need to tackle this back door transition. Whats the best way to install to this door? Leave a gap and caulk, replace the metal transition? Thanks in advance for any help.
Old 12-10-19, 01:31 PM
XSleeper's Avatar
Received 1,899 Upvotes on 1,705 Posts
Pretty sure that aluminum sill is part of the door, (screwed to the jambs from each side) so I dont think replacing it is an option. I would probably gap it 3/16" and caulk it. You could also create your own transition. Basically a piece of wood slightly thicker than your flooring (maybe 3/16" - 1/4" thicker) that would sit in front of the door sill... but notched on one half with a rabbet so that the floor can partially slip under it, and hide the expansion gap.
