Fake Stair Tread Thickness
I’m going to make my own fake stair treads (end caps). I’ve noticed all pre-made that you can order are 1/2” thick. Can I use 3/4” with no height problem next to carpet? I’m asking because I’m using a tongue and groove router bit for bullnose and tread. My bit is for 3/4” inch stock.
Will there be any exposed wood in the stairway or will it just be the ends protruding beyond the balusters? If it's just outside the balusters I don't think the extra thickness will hurt much. If you have wood inside the stairwell it could be a bit annoying for the wood to be higher as the carpet will compress when you step on it making the raised edge of the wood glaringly obvious and maybe a bit painful for tender feet.
