underlay ?
Old 05-18-20, 11:11 PM
underlay ?
after some advice Im fitting solid oak floor to a old 1940s house plank old floor its in good shape and very even ,should i put an underlay down or not ?
Old 05-19-20, 05:17 AM
Marq1's Avatar
Received 243 Votes on 230 Posts
What kind of flooring are you installing? And, what does the manufacturer recommend?
Old 05-19-20, 10:52 AM
22mm oak planks ,it just says As with all timber flooring the product should be acclimatized before installation and provisions must be made for expansion. The flooring can be glued or nailed into position.
Old 05-19-20, 01:23 PM
sam floor's Avatar
Received 12 Votes on 9 Posts
I would probably put plywood under it. The old plank floor will expand and contract which could cause problems with the new floor.
