Transitions against molding or under?
Old 07-12-20, 11:58 AM
D
Received 1 Upvote on 1 Post
I have a transition from vinyl plank to carpet between rooms with baseboard molding along the walls. Is it best to put the baseboards down first and butt the ends of the transition up to them, or is it best to put the transition down from wall to wall and notch the underside of the baseboard to go over the top of them. I am thinking the first option would be easier to make it looks seamless but thought I'd ask you guys.
Old 07-12-20, 02:55 PM
XSleeper's Avatar
Received 1,714 Upvotes on 1,538 Posts
Yes, baseboards first, then transitions fit in between,
