Hardwood flooring in closet
Old 08-09-20, 12:31 PM
Hi there! We decided to use some leftover wood in a tiny 9x7 room. Our floors were done by a professional but we wanted to try and tackle this ourselves. I'm going to use it as a sewing room. Almost done (ran out of wood and trying to find a slat instead of buying a whole bundle is a little challenging) I sort of wish we just went with simple flooring because I realized we're going to have to sand it prior to staining. I shouldn't do it with my little rotary sander right? I should rent a big sander from Home Depot or is that overkill ? Thanks for any help!
Old 08-09-20, 01:34 PM
XSleeper's Avatar
Received 1,975 Upvotes on 1,771 Posts
Yes, you will want a floor sander and one for edging.
Old 08-09-20, 04:36 PM
Thank you, XSleeper! So 2 sanders😩it's turning out to be pricier and more work than I anticipated.
Old 08-10-20, 03:01 AM
Received 875 Upvotes on 766 Posts
My office is just a tad smaller than that room [6x9] and I sanded the entire floor with an edger. It worked well for me.
Old 08-11-20, 03:20 AM
Marksr I'm thrilled to hear that! Thank you!😁
Old 08-11-20, 03:52 AM
I forgot to add that I did the final sandings with a quarter sheet sander. .... but the bulk of the sanding was done with an edger.
Old 08-18-20, 04:48 PM
F
If you were willing to put a little more work into it you could use a a hand belt sander and a random orbital sander. But actual floor sanders are always better.
Old 08-18-20, 05:03 PM
We are 2 rows short so haven't gotten to that point yet but thanks! Trying to avoid buying a whole bundle.
