Rim Joist too Tall?
Rim Joist too Tall?
I had an 4 foot section of rim Joist installed to replaced rotten ones. This house has two sandwiched together. the new ones seem to be 1/8" taller than the old one. Is this common. Is it that the new ones now days are cut different or from manufacture. I would have never thought to measure. I assumed a 2x10 was a 2x10. Should they have ripped it or will it shrink over time when it dries more. This creates a problem. Now 12 " x 3' section of sub floor that was replaced is up 1/8 " above existing floor. should I cut sub floor now to lay just on the joist? is this a common method because this is how someone installed it last time when it rotted 20 years ago. Thanks.
Harvard Design Magazine: Nominal Versus Actual: A History of the 2x4
