Vapor barrier under Pergo laminate question
Old 11-19-20, 06:05 PM
R
Received 1 Upvote on 1 Post
Hello, I have concrete floor and bought Pergo flooring that has an attached underlayment. My understanding is that I just need to have a vapor barrier under it and I'm set. My question is there any difference from this product.
HDX 10 ft. x 25 ft. Clear 6 mil Plastic Sheeting (I have some left over from a previous project)
https://www.homedepot.com/p/HDX-10-f...-25C/204711657
to this product?
MP Global Products MoistureBlock™ Floating Floor Underlayment Vapor Barrier
https://www.menards.com/main/floorin...0301738&ipos=6
Also, I noticed some stains on the carpet around the edges of my basement where I'm installing the flooring. While I've never noticed any water seeping in, do I need to worry about any sort of caulking or barrier around the edges of the house? Thank you!
Old 11-19-20, 10:10 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Your best bet is to review the manufactures specifications for installing the material below grade, some is not recommended with or without a vapor barrier!. Should take a look at vinyl flooring!
